It is currently Wed Aug 06, 2025 2:01 pm
 Post subject: Chalk marks ?
PostPosted: Thu May 17, 2018 2:08 pm
Hi
Anyone had white marks in there indian rosewood grain.
I thought it was maybe chalk at first but water and methalated spirit wont remove it
Any ideas
Sent from my SM-G960F using Tapatalk
 Post subject: Re: Chalk marks ?
PostPosted: Thu May 17, 2018 2:20 pm
First name: Brad
Last Name: Combs
Probably mineral deposits... viewtopic.php?f=10101&t=30651
There was a more recent thread on this that I can't find that had some solutions as well.
These users thanked the author bcombs510 for the post: cablepuller1 (Thu May 17, 2018 3:53 pm)
PostPosted: Thu May 17, 2018 4:31 pm
Last Name: Sollod
As I recall, muriatic acid had been suggested. Someone also suggested lemon juice. I tried it and it worked for me...
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: cablepuller1 (Fri May 18, 2018 10:14 am)
PostPosted: Thu May 17, 2018 7:26 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I haven't seen that in Indian Rosewood. I have seen it in Brazilian and it was from mineral deposits. I picked it out with a hand sharpened scribe type tool and checked every so often so often with a coat of shellac to see if I got it all.
These users thanked the author Tim L for the post: cablepuller1 (Fri May 18, 2018 10:14 am)
PostPosted: Thu May 17, 2018 10:22 pm
First name: Aaron
Last Name: Craig
State: Missouri
Looks like mineral deposits. I would ignore them until the last bit of finish sanding and, if they are still there at that point, use a dental pick and or large sewing needle to pick them out of the pores. They stick out much less under finish.
Aaron Craig
These users thanked the author jac68984 for the post: cablepuller1 (Fri May 18, 2018 10:14 am)
PostPosted: Fri May 18, 2018 5:42 am
typical of EIR and very common
I use CLR never heard of the lemon juice but will have to try it.
With CLR is use a tooth brush and then rinse with water.
These users thanked the author bluescreek for the post (total 3): cablepuller1 (Fri May 18, 2018 10:14 am) • Pmaj7 (Fri May 18, 2018 8:38 am) • Jonny (Fri May 18, 2018 6:16 am)
PostPosted: Fri May 18, 2018 9:22 am
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
Acetone seems to work as well. It makes the natural oils in the EIR stain the deposits. Haven't tried CLR but I have some so the next time I need to I think I'll try that.
"I've been had again"
Tim Benware
Creedmoor, NC
These users thanked the author Ben-Had for the post: cablepuller1 (Fri May 18, 2018 10:15 am)
PostPosted: Fri May 18, 2018 10:22 am
have seen this before. trees suck up an amazing amount of stuff when they're alive. take a look at the feeder tubes of some mahogany under a microscope sometime -talk about clogged pores. ever power sanded some wood and saw sparks?
possibly calcium? or an oxide of some sort? i'm no chemist. maybe you can get it tested by a friendly lab rat who owes you a favor?
These users thanked the author arie for the post: cablepuller1 (Sat May 19, 2018 9:23 am)
PostPosted: Fri May 18, 2018 10:37 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
This is typical in quite a few woods, so predominant in Merbau that it is used an an identifier. Likely some form of silica. in some woods it can be near invisible, but this is what makes some so hard on blades and bits.
B
These users thanked the author Bri for the post: cablepuller1 (Sat May 19, 2018 9:23 am)
PostPosted: Fri May 18, 2018 2:48 pm
I have used acetone, and dilute HCL with a toothbrush. Always seems like I still have to dig a few out.
I will try CLR. The deposits appear to be a Calcium compound so they are most likely a base and one would expect an acid to dissolve them.
I asked Jim Olson once what he does and he said he usually winds up digging them out one by one with a needle.
These users thanked the author Terence Kennedy for the post (total 2): Pmaj7 (Wed May 23, 2018 11:23 pm) • cablepuller1 (Sat May 19, 2018 9:23 am)
PostPosted: Wed May 23, 2018 5:28 pm
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
Distilled Vinegar (not Apple Cider) works for a lot of white stuff. I also use a soft brass brush designed for cleaning wood files - works much, much better and faster than something like a needle or awl.
These users thanked the author Toonces for the post: Pmaj7 (Wed May 23, 2018 11:24 pm)
PostPosted: Sat May 26, 2018 8:00 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Acetone should work. I know denatured alcohol (or ethanol) works. Like Ben says, those deposits in Indian rosewood are porous, and will soak up the color of the surrounding wood if you pad over the surface with a suitable solvent. Brazilian, on the other hand, has silica inclusions that behave...well. like silica. They are as hard as glass, and they absorb nothing, dissolve in nothing. (Theoretically, they should dissolve in hydrofluoric acid. I haven't tried that. I'd worry about the damage to the wood.) Pick them out, or call it character.
PostPosted: Tue May 29, 2018 8:44 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
If they still show after I rub a coat of shellac on, I hide them with a brown Sharpie marker.
PostPosted: Wed May 30, 2018 8:51 am
Last Name: Sollod
hydrofluoric acid is bad stuff. ...dissolves bone.
Users browsing this forum: Bing [Bot], Glen H, ptourin, RaymundH and 17 guests
